2009 Ram Key fob programmer
N
nuwk3r
USA
Has anyone used this programmer or know of a programmer that will work?
RedFalcon
Katy, TX
For that price, I would look into simply taking them to a local locksmith. I've had fobs programmed in the past for a reasonable price this way vs taking it to the dealerships
N
nuwk3r
USA
Thanks for the reply RedFalcon. I called the dealer and they quoted me $300 for both fobs. I called the locksmith and he quoted me $125 to program with no guarantee. So I was tempted to try this programmer for the price. I see it does 2009 Dodge Ram but it says Canada. I'm not sure what the difference would be between a truck manufactured in the USA. I thought I would try the forum to see if anyone else tried this CK100 out on their Ram. I think I may give the programmer a try.
RedFalcon
Katy, TX
I do know that there is a difference between the ones manufactured in the US and Mexico. My friend has one built in Mexico and we find all sorts of little things that make working on his truck more difficult or at least more of an inconvenience because we need a different part or tool.
Somewhere buried in the forum, there was a thread with a link to a site where you could put in your VIN and it would spit out your build sheet for your truck. I believe that it has a note in the build sheet about where it was assembled.
N
nuwk3r
USA
Thanks for the help. I did find a VIN decoder here: https://www.dmv.org/vehicle-history/vin-decoder.php
It does show Warren Truck Assembly.
Decoded VIN:
Make: DODGE
Manufacturer Name: FCA US LLC
Model: Ram
Model Year: 2009
Series: DR / Light Duty
Trim: 1500
Vehicle Type: TRUCK
Plant Company Name: Warren Truck Assembly
Body Class: Pickup
Gross Vehicle Weight Rating: Class 2E: 6,001 - 7,000 lb (2,722 - 3,175 kg)
Drive Type: 4WD/4-Wheel Drive/4x4
Brake System Type: Hydraulic
Engine Number of Cylinders: 8
Displacement (CC): 4700.0
Displacement (CI): 286.81159724524
Displacement (L): 4.7
Fuel Type - Primary: Gasoline
Engine Configuration: V-Shaped
Other Engine Info: Sales code:EVE
Turbo: No
Seat Belts Type: Manual
Front Air Bag Locations: 1st Row (Driver & Passenger)
Side Air Bag Locations: 1st Row (Driver & Passenger)
