Whiskeyjack
I have a 2010 2500 4x4 with the 6.7 engine. I am experiencing a bizarre issue. Earlier this week, when I put the truck in gear (Drive or Reverse) it would operate normally until I pressed the gas pedal. Then it would lag for a second and surge. I would put the breaks on and it would try to surge through the breaks as I quickly put it in park. It was repeating pretty regularly. I had a more intermittent version of this issue earlier this fall that went away when I changed the hub and u-joint on the passenger side. When this started earlier this week, I remembered that I needed to change the drivers side hub and u-joint. With the new hub and u-joint installed, it only does the surge when I put it in reverse. I am not a mechanic in any since of the word. I can google how to do "x" repair and generally be able to accomplish it. Slowly, but I can accomplish it. I tried googling this and out of 4 browsers, I got 4 different solutions to the problem. Has anyone here had this problem or better yet, solved this problem?
