twseeman
After checking all fuses, relays and etc in TIPM to check for a battery drain, my Radio / Key FOB stop working. I also get a "NO FUSE" error when first starting pickup. I checked radio fuse and is good. Is it possible I fried a relay in my battery drain test? I cannot find an online listing of the relays in my pickup. Another issue I was having prior to my battery drain test was my system was locking the doors without me touching the Key FOB. Is there a component that would cause these issues that I can check out? After a bit of investigation, I am concerned I could have a TIPM issue. I attempted a hard reset of the TIPM, which included disconnecting the battery connection and connecting the positive and negative cables together overnight, no change. Any help / suggestiong on this would be greatly appreciated! Tom
