2011 5.7 Ram with Stage 1 cam, long tubes 6.4 intake, catless y pipe stock cat-back Dyno 345hp what’s going on?
CaptQ
Minneapolis
Exhaust gasket,and port match the manifold to it.The port match anybody can do with a die grinder and carbide bit and sanding rolls,but the extrude honing is something you'll have to have done by an outfit that specializes in it.
Extrude honing entails pushing an abrasive median through the manifold under pressure
You’re not as knowledgeable as you think you are
Runs like dog ****, it has less power then when it was stock. They bent 1 tube from the header because it wouldn’t clear, so 1 exhaust port is struggling. This dyno graph look like **** to anyone else?
Usually HHP has a good rep with tuning,but if you think it's not right you could try another shop specialising in Hemi's
S
Scomer412
Royse city
For your mods,those are very respectable numbers for an RFE equipped truck.They could tune the SRV a bit more though,as the big dip at roughly 4100 is when the intake is switching from long runners to short runners
This was before they had to bend 1 of the headers to about half the size it was before. Driving it now it’s extremely slow, like zero power
S
Scomer412
Royse city
Unless they specialize in Mopar tuning alot of dyno shops are in over their head with a hemi.You might want to find a Mopar only shop
How much power do you lose by collapsing one of the exhaust header ports to half of its size just to clear the steering colum. They gave me this result, then took the headers back off and bend 1 of them to half of the 1 7/8 size. It’s like 3/4 of a inch and smashed down to half the size and it rubs when I try to turn. Very dangerous and the steering wheel gets hung up
They shouldn't of had to dimple/bend them that much to clear the knuckle on the steering shaft,plus if it's still binding on a corner,they didn't dent the tube in the right spot. Engine Masters did a test a few years ago,and they had to literally flatten a primary tube,before they started to notice a power drop on the dyno,so i wouldn't worry to much about the dent,but i'd be perturbed if they flattened it in the wrong spot,and it still causes issues.Hunt up Bandit post on steering shaft interferance,as he moved the knuckle up on his truck.Some guys use the shaft extension for a body lift to move the knuckle up higher,if you don't like welding
S
Scomer412
Royse city
So you don’t think I lost any power? I can tell you max power is 4300 rpm, and it feels SO SLOW. Stock was way way faster.
Is it normal for the graph to be spiky like that, I thought they should be smooth through the ban
S
Scomer412
Royse city
Sorry guys I’m freaking out cause I spent 8k and my truck is slower then before, like a lot. My track time would be in the high 15 I’m guessing. It hesitates, goes no where at 3500 rpm. If I don’t punch it, it wont speed up.
Do you think I need a better tune? Also where can I get something to move the knuckle son steering?
I’m so sad right now, sorry the way it drives is heartbreaking
S
Scomer412
Royse city
Do you think they did the 6.4 intake install improperly? Or just a really bad tune. There is like zero torque
S
Scomer412
Royse city
I’m in tears, that’s how bad it’s running. Does this dyno graph look like it’s done right?
S
Scomer412
Royse city
Not tuning mopar. I would get smoked by a stock 5.7 right now, no way I would be able to keep up with one.
I’m so upset, someone tell me what’s the graph looks like. Where is the gradual gains in power
By the pictures it looks like they did a nice job on the intake install,but that's all we can comment on about the manifold install.By the looks of your dyno graph,it appears like the short runner valve is working,so it should of gained some torque down low. When you say "Stage 1 cam" what do you mean,cams are usually listed with lift/duration/lobe seperation angle etc, so saying it's a stage 1 cam doesn't really mean much. You're in Dallas so you're not far away from Matt Fikac at Moes,maybe go see him,and see what he says,maybe he'll line you up with Sean Powell or somebody else to take a look at your tune and see if it's right for your combination. Have you told HHP you're very disappointed in the power the truck is producing,if you're nice about it,they should be willing to take another look at the tune for you.
S
Scomer412
Royse city
When I left tonight I told them the steering was rubbing and my steering wheel was not turning without grinding. They said that’s all they can do with the crap headers I brought. They couldn’t get theirs so I bought some crap eBay headers. 1 side fits the only was squashed.
Either way timing or something is off.
Texas Speed cam
214/222 .582/.582 112+3
Long tubes, 6.4 intake. The power at 363 whp is fine, but zero torque and super slow like I’m pulling a 10 ton weight. Without pressing the pedal almost all the way down it doesn’t want to go, it really has to struggle and you can tell something is holding back Bigtime. It can’t be stock cat back since it has no cats and long tubes.
Is that a mild cam?
Johnnguyen6596
