2011 ram 1500 radio bezel
qualityisland
4.7 v8
Hey everyone im new to the ram forum so bare with me! And thanks in advance for any help!
I recently picked up a 2011 ram 1500 and im looking to replace the stock non navigation radio with my pioneer double din nav unit from my last ram. When I put the unit in my old truck I had to get a different bezel and I was wondering if I need to do the same with this truck? Also is there any efficient way of finding which bezel I might need (to match the interior correctly)? My local dealership doesn't seem to be able to find this information!
Thanks,
John
MikeG
Livonia La.
You just need a install harness, install kit and do a little trimming on the metal mount braket for the oem radio.
ram-head
Arkansas
No bezel, but like was said...a dash kit. Fills in the gaps on the sides of the unit. You'll probably have to cut or trim a metal bracket along the top of the cavity as well.
ram-head
Arkansas
Oh yeah...and a harness that'll set you back around $130 if you use Cruthcfield or a local shop.
S
scotts2012ram
Guest
I found a much cheaper harness that worked in my truck it should work in most base model radios without the factory amps. Its just a pig tail harness that i got off ebay everything works like it should only thing i had to do was tap into a key hot i used the cigarette plug for it. I paid 28 for the harness and radio mounting kit.
Q
qualityisland
4.7 v8
Thanks for all the help guys! Radio is in the truck :)
Ghstrdr95
