2011 ram rear differential
brandonj1345
Port saint lucie
Hey all I have a 2011 dodge ram 1500 4.7 . I took it to a shop due to a bearing noise.they said it was my pinion bearing going out and quoted me 2k to rebuild my differential. My question is there any other years that I could get a used one from in the meantime.
2011 should have the ZF rear end,so anything from 2011 to 2023 will fit if it's a 4th Gen truck including the Classics.The 2013 and newer diffs might need the abs sensors relocated,but thats easily accomplished with a die grinder.
62Blazer
Midwest
There should be many years that will fit. Just make sure you get a matching gear ratio.
