SJC
I have a 2012 with 3:55 gears. I was told that it is impossible to change the front gears out. My only option was to find a 09-11 differential, driveshaft and axles install the gears of choice then install into the truck.
For front on the newer Rams the gears are welded in so it really isn't a bolt unbolt swap.
If I've read correctly it is something to that effect, one of the best people to pose the question to is Matt at Moes.
Ugh that sucks. Guess I'll try and track a front end down.
I have 4.10s. I'm running 275/70/18 BFG AT TA KOs, which are pretty close to stock height.
In 1st gear, at 2000 rpm, I'm doing about 15 mph. At 2000 rpm in overdrive, the truck is going 70 mph. At 55 mph, the engine is spinning just 1600 rpm. As you can see, 4.10s in these trucks is not low at all. It "middle of the road" by my standards.
If you throw 37s at a truck with 4.10s, and you get a giant dog. 4.56s and 35s might work.
Personally, I think 37s look stupid. They'd have to be hard on brakes, U joints, the tranny, steering, and who knows what else.
If your gonna go through with all this axle swap stuff go big or go home and get 4.56 especially if you plan on the lift and tires. even if you dont, 4.56 wont be too little gear on the highway with 35s plus that thing would run like a scalded dog
.02![]()
