tx1500ram
I just bought a 2012 ram 1500 and am hoping to do an interior overhaul. I was looking to upgrade the dashboard to a more modern dashboard like the ones in the 2020 models and was wondering if anyone has any experience of where to buy them and how to install it. I also want to upgrade to CarPlay and wanted to know if anyone had any suggestions on that too.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Many of the OEM electronics will be compatible for a 2012. Changes occured in the 2013 refresh that will make many OEM features unattainable for a 2012. If you want Carplay, you'll need to go aftermarket.
tx1500ram
tx1500ram
so for the dashboard could I just buy a dashboard from a 2018 truck?
jawzs2
Air Force
South Jersey
been asked 100 times on here - if you are asking about the gauge cluster\speedo, nope - it won't work. No idea if you're only asking about the dash pad.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I "think" the dashboard and seats will bolt up but none of the associated electronics in those items (except power seat movement) will work.
Manump95
Canada
Do you know if will be possible swapping the seat module control to the 2012 will help with that? Or won’t work either way
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
If it's just a power seat and not heated and cooled or memory, you will have no issues. Power adjustment seats are just 12v power to the seat harness.
