2012 Ram 1500 Towing Question
Gene Knox
San Antonio
Hello and Good Afternoon to all,
I have read most of the forums in here regarding towing however I have not found any that references RPM's.
So here is my situation:
I have a 2012 Ram 1500 5.7- 6 speed sport shift c/c short bed, 20" wheels. 57000 miles
3.55 gears.Tranny cooler K&N filter in factory housing.
Oil: 5/20 full synthetic (Mobil 1)
Trailer: 31ft Mallard M260 (alum frame) split axle.
Hitch: 10,000lb Wt. dist. with spring bars, dual sway controls, towing in Tow/Haul mode, the trailer is perfectly balanced and tongue wt is correct.
So here is my question:
While towing on flat ground open highway mainly I-10 / I-12 the truck will run at 1900 rpm @ 60-63 mph. any increase in speed or incline the engine will elevate to 2500 rpm. and loose speed, and if I give more gas it will jump to 3000 rpm or more. The TAC has no visible redline on it. It seems like I am all torqued out on an incline at the speed while running the incline.
Now let me tell you I have no issues running at the 60-63 mph for however long it takes to get from point A to point B.
My concern is the RPM that the engine is running at, it makes me nervous to have the rpm's so high.
I've had the rig weighed connected and here are the numbers:
front axle 2820 lb.
drive axle 3640 lb.
trailer axle 5740 lb. (according to Dodge's listing this is way within the weight limits of this set up.)
gross weight 12200 lb., Weighed at a pilot truck stop. Ea, axle on its own pad.
Will running the engine for long periods of time at the 2500 rpm's cause it to spin a bearing on the crank?
Is 3000 rpm's way too much?
I have had the engine at times rev up to 4000 rpm while either overtaking a slower rig or being caught on an incline while overtaking only to have to fall back in line to let traffic pass.
The weight does not account for my weight 175 or my wife's 150 and 3- 50lb dogs in the back seat. Yes, I know it's cramped back there but they are troopers.
So, if this is enough info can anyone out there give me the info I am looking for since I don't want to blow this engine or transmission while out on the road.
We are centrally located in Texas and as of now we stay below Dallas and travel west and east for now. I however do want to start traveling north but I'm afraid the present rig would not be able to safely handle the hills and long climbs like in the Dakota's, and east and west of there.
Thanks in advance.
The problem is the spark plugs, as in you have them. If you want to tow at 2K rpms you should have bought a diesel.
Your Hemi torque peak of 410 ft/lbs is at 4K rpms where as the EcoDiesel 480 ft/lbs is at 1600 rpms. It's not horsepower that tows a trailer but torque.
You can put you mind at ease, the Hemi will hold that 4K rpms all day long if needed, your "fear" of high rpms is unwarranted. Also keep in mind that lugging a gas engine can damage the engine, so use the Tow/Haul mode to keep the rpms up where they need to be.
dhay13
Sounds about right. I had a 2013 5.7 with 3.55's and towing a 7500lb TT I was running 3000-4000 RPM on the highway
CanuckRam1313
Ontario Canada
2023 Warlock
What chash68 said!
These HEMI's are workhorses. As long as you maintain your truck these rpm's won't hurt it.
Heck, I regularly push my HEMI past 5K where the VVT kicks in and hold it to its stock high level shift points running through the gears whilst I enter the highway, and keep her highly spirited as the acceleration continues to her cut off (sometimes).... Our Lady of Blessed Acceleration... ;)
ramffml
ramforum
Your RPMs sound normal and inline with my truck. I tow at 2300 RPMs and hit 3000+ up steeper hills, no worries at all.
But if I were you I'd run a high quality 5w-30 synthetic oil. Redline 5w-30 is an excellent candidate, or if it's too pricy for you then Mobil 1 FS 0w-40 with 12oz of BioTech Lubeguard. (I'm running HP oil but haven't yet towed with it nor had it analyzed yet so can't yet recommend it though I suspect it will be my permanent oil choice.)
Watch your oil temps and stay below 250F. Slow down or take a break if you hit those temps for more than 10 seconds while cresting a hill or whatever. If you have active grill shutters, you can buy a few seconds of cooling by removing them. I've also purchased an external oil filter relocation kit which should help keep the engine a little cooler as well.
You don't need a diesel lol. The hemi still tows more. The problem is not the engine revving to 80% of redline, the problem is our misunderstanding of damaging the engine by doing so. Once you realize the engine doesn't care (proper oil/temps notwithstanding) you'll be more comfortable towing with it.
Also you may be a little surprised/happy to hear that the 5.7 was used in the 2500 heavy duty trucks. It's seen a lot of work and abuse, there are no real issues that have arisen from working the 5.7 hard.
Oh, also change your oil no later than 5000 miles when towing. I'd also recommend running 89 octane while towing, it will keep your engine cooler with a cleaner burn.
09SilverRam
The South
You may want to leverage the auto-stick functionality of the transmission to manage shifting in tow haul mode. The transmission lets the engine lug down too much before downshifting when climbing on its own, my truck does a much better job of holding speed and not hunting gears when when I set the highest gear and then kick it down manually as we start the hill before the truck slows down.
Don’t be afraid to spin that engine up.
62Blazer
Midwest
2,500 to 3,000 are not excessively high RPM's by any means for this engine. I would not hesitate to run sustained periods of times in that range, and it may very well be better for the engine engine to run 2,500 to 3,000 rpm versus lugging it in the 1,900 rpm range. My last trucks was a Chevy 2500HD 6.0L gas and it would run almost 2,500 rpm at 70 mph just cruising down the freeway empty because of the gearing. When pulling heavy, especially with any type of head wind or slight grade, it would drop down a gear and I would cruise at over 3,000 rpm for extended periods of time. Also wasn't unusual on steeper grades for it to downshift again and it would run in the 4,000+ rpm range up the hill. When I traded in that truck is had over 150k miles on it and ran great.
G
Gene Knox
San Antonio
Hey thanks, yea Kinda thought it was the plugs causing the issue. However, I could not pass the deal at the time I bought it. 26520 miles and only 469 hrs on the motor. I would love to have a diesel however parting with 65-70k to tow a trailer that as of now is done like 4-5 times a year is a little hard to justify, for now. I have 8 more years to work before I decide to retire, I will most likely purchase one at that time. I appreciate your input though. Back in the day early 90's I had a chevy 454 that spun a bearing and caused me a lot of trouble. So I'm somewhat gun shy.
Octane
U S.A.
That 454 was known to break a crank back in the day also. In our experience locally here.
G
Gene Knox
San Antonio
Hmmm, never thought of that, actually I have never used the sport shift feature since I have had the truck ( 3/21) I bought it off of a widow whose husband only went to church and the store in it. when I bought it the motor had 469 hrs on it I believe and 26k miles. It was only after that we traded up to the trailer we now have. The next time out I will have to see about that manual shift feature. Thanks,
G
Gene Knox
San Antonio
So are you saying that the Mobil 5/20-5/30 synthetic is not a superior oil? I've looked into redline but never bought it, I figured it was just a name and therefore that's what you are paying for. I had a machinist that rebuilt engines for Nascar tell me that the Mobil 1 is what they run. So, I figured it was good for this engine. My oil temps had been running in the low 300 deg. range. however, that was during the summer last year when it was 105-109* in July Aug. Thought of adding a oil cooler however haven't had time to research the concept yet. however, the lower thin portion is solid just looks louvered and will be changing to billet look to get more air across the oil pan on bottom. no grill shutters.
As for the fuel I usually fill with 89 or 93 when towing it seems to burn better but hey it's most likely me and you know the macho concept LOL
As for the diesel concept one day I'll get there but for now I'll use this.
I usually change my oil @7k intervals but yea I see your point.
Thanks,
ramffml
ramforum
I'd never run any brand 20 weights anymore in the hemi. The more I read on bitog, the more I'm convinced that 20 weight is a problem in our trucks though most will likely be "fine" running it if you don't keep your trucks long etc.
I also don't know much about Mobil and to be honest I'm the wrong guy to ask. The oils I mentioned are based on other expert opinions on the forum and many user reports especially with Redline 5w-30 and its ability to mitigate hemi tick. The synthetic oil thread is a great read but the oils I mentioned are recommended there.
For several years before 2009 & a few years following, Chrysler Engineers called for Mobile One to be used in all Chrysler engines
Then for one year, Chrysler gave the Lubrications Contract to Valvoline
Then every year since then Shell Oil has won the Lubricants Contract
( there is a reason Shell has won the Lubricants Contract, no one else is competing )
The funny thing is Shell, Pennzoil, Rotella is not at the top of any list done by the companies that rate oils
danielmid
Southeast WI
2015 Sport 4x4
Thanks,
300 degree oil is pull over and stop territory in my opinion. That is ripping hot. Towing our camper up and out of Phoenix mid-summer we didn't hit over 260ish and that was on the longer pull sections. If you're getting that hot just driving around then something else is up.
62Blazer
Midwest
I understand where you are coming from regarding the ealry '90's 454 comment, but you are comparing apples to oranges when throwing a 5.7 Hemi in there. The 454 is based on 1960's technology and probably had a redline at maybe 4,000 rpm and designed to lug around at 2,000 rpm. The 5.7 Hemi is 40 year newer technology with a redline in the 5,500+ range in trucks and should spin at 3-4,000 rpm all day.
G
Gene Knox
San Antonio
No, that's pulling the trailer at 65 mph in 105* temps no air blowing and on an incline, it went back to normal after I paused for about 45 min. I was scared seeing that and almost thought it was an anomaly. once cooled all was well.
G
Gene Knox
San Antonio
I won't run Penzoil synthetic in any engine I own, they use paraffin as a byproduct in their oil to allow for the viscus to be in align with the other brands. It also allows them to produce it at a cheaper rate and therefore compromising the engine,
danielmid
Southeast WI
2015 Sport 4x4
I respect your opinion, probably a bit old school, but hundreds of used oil tests would disagree with you.
06 Dodge
6.7L CTD
IIRC in the mid to late 1970's Pennzoil with Z 7 was said to contain paraffin wax, to the best of my knowledge no one ever provided proof, so if you have that proof please do post if for all to see and learn...
doc 11 ACR
Wisconsin
I have a 2010 2500, 5.7 6-speed, 410 geared 4x4 that pulls my 9,000 lb camper with ease. Yes, it revs on grades and if it hits the limiter (not often) it will drop back also. But that Hemi just wants to run. Keep up with your PM's and use a good synthetic oil. I use mobile one high mileage for the extra additives. An oil cooler would not hurt either. Good luck
KAKA
