2012 Ram 2500 suspension
Nick1972
Ohio
I have a 12 Ram 2500 with a Snow Dogg 8'6" V plow. Any recommendations for upgrading front springs for better support of heavy plow. I use to have a Snow Dogg MD 7'6" with no drop or sag issues using Rough Country 2" spacers. Now even with spacers get at least 2" drop when raising plow. I am currently looking at Tough Truck Coils TTC-1216 which is all spring with 2.5" lift on it. Have seen good reviews on them. Anyone running them or anything else to support 1000lb plow.
Derek Powers
It will likely ride like ****. Look into timber grove air bags
NewBlackDak
6.7L Cummins
I would go with bags, or custom cut dual rate springs. I got a quote for some, and they were under $800/pair.
RamminMopar
I'm looking into superlift #k515 it's a 2 inch coil level with shocks (4) for like $320ish
Derek Powers
Fyi...almost all of the aftermarket leveling kits that include the coils are not rated a plow.
olyelr
Kewadin MI
exactly. Most aftermarket coils will probably have less spring rate than the stockers... equalling more sag.
if the stock spring rate is too low, I would suggest air bags for the front. That way it dosnt ride like a dump truck all summer when you dont have the plow on.
