Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Seal kit. Pitman shaft. Steering, gear, power, box. Ram 1500. Genuine Ram Part - 68053783AA. Ships from Myrtle Beach SC
www.moparpartsinc.com
If it's a steering rack, usually they can be replaced but i haven't done one for a Ram. There's a video link below. I would avoid drilling a hole in the seal though (unless necessary).
Either way, I would suggest punching a small hole with a sharp awl or nail, (unless you have to), then thread a short screw ...somewhat blunt on the end (only not as far as the kid did in the video below). Or take a small chisel and open up a crevice which you can slide a screwdriver into and pry out. You don't want to risk damaging the ball bearing cage (if it's plastic) or get shavings inside.
