bkram2500
- May 28, 2017
- 6
- 5
- 2013
- Hemi 5.7
Hello, Im new to the Forum. I have a 2013 Ram 2500 with 5.7 Hemi 4wd. I recently replaced my front brakes and rotors and now they are pulsating. I can feel it driving around town but its really bad when I set the cruise at about 65/70 and when I brake to exit the pulsating is really bad. I took them apart and greased (w silicone) the caliper slide pins. Today I replaced the the Rotors, still there. Could this be a stuck caliper? When I originally replaced them The right side pad was down to the metal but the left side was over 50% pad. I also had a cracked rotor on the right side. The truck only has 31k miles and I did not notice ant pulsating before changing the brakes. I checked all of my wheel weights and the tires are brand new. Being only 3 1/2 years old I dont think it would be a clogged brake line, but I'm not sure, I'm thinking stuck caliper. If so should I just replace the right side? Thanks for you time and any help
