2013 Ram Sport with 8.4, adding backup camera
mpicc84
North Eastern, PA
My buddy has a 13' sport, but is missing a few things. Oddly enough he does not have the sport hood, nor a backup camera.
Going to put a backup camera in his truck. Can I simply "plug in" a aftermarket tailgate handle camera and away we go? is the OEM tailgate handle camera worth the extra couple dollars?
And does he need a dealer flash to "activate" the backup camera / options within his 8.4 (Non-Navi) factory radio?
baum
savage, mn
2015 Laramie
Any aftermarket cam will work.
with both the "factory kit" and an aftermarket you will need to run all the wires and also have it programmed
the biggest advantage to the "factory kit" is you will get the active (moving) grid lines
mpicc84
mpicc84
North Eastern, PA
Those are nice. So a trip to the dealer is needed regardless? I was hoping to avoid that part haha.
Sent from my XT1585 using Tapatalk
baum
savage, mn
2015 Laramie
unless you use an aftermarket with a lockpic type device there are many of them so just search on here
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Take a look at post 10 of the OEM Camera thread if you haven't seen it. Direction links are there also for comparison.
Sent from my non-flammable Galaxy S7!
UrbanKnight
I paid $230 on ebay for the handle, camera and box that avoids the trip to the dealer.. Couldn't be happier
mpicc84
mpicc84
North Eastern, PA
Can you link me to this?
I will check out that post 10. Thank you!!
00R/T
CT
Buy the factory kit. Everything fits perfectly and is high quality. If you really, really don't want to go to the dealer you can find someone with a scan tool or drop $200 on an OBDGenie.
mpicc84
mpicc84
North Eastern, PA
Wait, A buddy of mine is a mechanic, has a OBD scanner by SnapOn. I think its a Solus or something. Does this have the function? I know he just uses it to read codes and reset things.
UrbanKnight
Aftermarket is no better or worse than factory... Other than the camera, the factory dodge camera is pretty crappy resolution.... my aftermarket is much clearer than my factory camera...
No the snapon scanner can't add sales codes
mpicc84
mpicc84
North Eastern, PA
Allrighty. Does anyone know the cost of the dealer flashing a code or two? I don't know how they would even charge for that.
00R/T
CT
It all depends on the dealer. If you have a good one, they might just do it for you if you come in for an oil change or to buy some parts. Others will bill you for a half hour or so at the shop rate.
Showing up at lunch time with a couple pizzas can work wonders sometimes too.
