VPRPWRD
- Aug 14, 2014
- 176
- 33
- 2004
- 8.3L Viper
Has anyone done this yet? Looking for recommendations and if you were happy with your choice.
Tuning and reliability has been the limiting factor with heads/cam on the 4th gens. Try reaching out to Modern Muscle in VA. They are building the 392" for our shop trucks, and we will be running their ported 6.4 heads and a bigger custom grind cam.
Just a note.. You cannot run 6.4 heads on a stock 5.7
The cylinders have to be notched to clear the valves.
If I remember right I've read about a few people trying 6.1 cams in the 5.7's and none of them gained much at all. However those were all in cars.I think somebody installed the 6.1 cam with little gains, but could of been all in the tune.
I've had this done at a time when there was very little tuning from diablosport. Even to this day, there is very little access by Diablosport into the VVT PCM. In a nut shell, there are modifiers in the pcm that fight the mods into emissions compliance that we don't have access to. My EGR monitor has never completed to a ready status. New maps and tables(Ve, Fuel, etc) were created, it took Arrington in concert with Diablosport, 2 months to make it happen.
Okay, now that most of the negatives are out of the way. Would I do it again, YES. The only thing I would do different is instead of the VVT 266 comp cam(Everyone at Arringtons said this was the right choice for these trucks), I would try a custom grind.
Truely a different truck from stock, completely changed the power curve. maybe 50hp gain @5600rpm but down @3000-3600, just shy of doubling the base numbers(131hp/181tq to 220hp/318tq). I would only consider 1 of 3 tuners for this job. AJ-Hemituner, Mike from OST, or Josh from HHP.
As a matter of fact, the truck is with AJ right now in Long Island getting tuned with MOES ported intake manifold. I should have fresh base numbers with the cam/head install after a year of letting the truck learn it's new design. We will see how the cam/heads will responded to some more air.
Do you have contact info for AJ? Thanks for the review.
I'll second this. AJ is the one who tuned my truck. He definitely knows his stuff and is great at what he does.Hemituner Performance
100 Dale Street
Westbabylon NY.11704
516-603-9276
[email protected]
AJ is a great guy to work with.
As for 6.1 cams in 5.7's in the cars I know a couple guys who have done it and are happy with the results. For having to spend less than $100 on the cam and to get some gains out of it seems to be a nice trade off.
The truck sounds mean. I like it.
