2014 No Crank. No Dash Lights. Dead Truck. Intermittent
NETim
Nebraska
5.7L
Searching threads here and elsewhere, I kinda get the impression that cleaning the battery terminals is a a good first step. So I did that. This appears to be the original battery. Along the way, I noticed that the black plastic (fuse?) block attached to the positive post appeared to be a little loose. (12mm nut)
I wire brushed all connections clean and re-assembled.
I also replaced the key fob battery.
The truck performed this antic to me today. I tried to crank it 2x in rapid succession with the same results. I pulled the fob and rotated it 180*, re-inserted and it cranked normally. I did not notice any lights on the dash anywhere until I flipped the key fob.
I did not think to try the remote start off the key fob at the time.
It did this once before a few weeks back and it seemed like I couldn't pull the fob. But I got it out after a bit of tugging, re-inserted the fob and it then started.
I've only had the truck since 2/23, so I'm still learning the "normal" indications.
It's been fine since the episode earlier today.
Maybe the factory battery is trying to tell me something?
mtnrider
Georgia
I'm betting it's the battery. These trucks do weird things when the battery is on it's way out. If that is the original one it's about that time.
