2014 RAM 1500 Express Crew Cab
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Doing a little calculation going to 37's with 3.92's will be the equivalent of having 3.55's with 33's.
If i wanted to keep the same ratio of 33's and 3.92's i'll need 4.30's though 4.56's will be best.
revitupmoto33
Flagstaff
Ecodiesel
Not yet, i'm on 3.92's that's why i haven't decided to fully embraced them. I have to contact Mobile Gear and see what they have to say about the RAM diff upgrade. they do the work for shops like Rebel offroad and others and can come to your house, still way cheaper than the local offroad shop. They charged me 1k OTD to change my JKU front/rear gears with parts and labor, and they did the job in about 2-3 hours right in my garage.
I’m curious to see if they have a solution for the front diff
revitupmoto33
Flagstaff
Ecodiesel
I have the 3.55 ratio in mine and when I had 33’s it wasn’t that bad but taller ratio would be much better
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Got the Bwoody rear trackbar installed. It didn't come with instructions and i didn't know if there was a recommendation where to place the side with the jam nut, so i put the jam nut side towards the axel. I did send bwoody an email to double check just in case but i'm still waiting for their reply.
Took the entire join out and coated the theads wit anti-seize
40714729323_9654e8f05a_h.jpgUntitled by RAM RSM, on Flickr
Measured the stocker at 33 11/16
40714729003_b99598e24a_h.jpgUntitled by RAM RSM, on Flickr
The Bwoody is thicker, hard to tell if it's solid or not but the stocker is definetely hollow and if you grab it in the middle with your hands you can feel/see how it twist, kind of crazy to think it's so whimpy considering these are trucks with a 10k lbs towing rating. The new one is a lot more solid and you can't flex that ***** like you can with the stocker.
47628030222_2fd6e3bc49_h.jpg2019-04-23_01-22-17 by RAM RSM, on Flickr
Final product
32737883597_a7f99855ae_h.jpg2019-04-23_01-22-37 by RAM RSM, on Flickr
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Forgot to add Bwoody got back to me and it this case it doesn't matter which side you pick to place the trackbar so i'll leave the jam nut side facing the axel.
hodge-xj
5.9 cummins
Next round:
Barricade HD Extreme rear bumper
Revitup Motorsports :) HD Spare Tire carrier with Provision to mount a Hi lift jack and Rotopax
ICI Throphy Prerunner front bumper
All the goodies!!! Notice any tighter feeling from track bar? You ain't kidding how flimsy this oem feels..
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
It's tighter yes, seems more controlled body roll. i like it. Been thinking about refreshing the rear control arms and the front LCA's being they have 71k miles but they seem ok so far what that heck i need to stop money spending for a while... If i go back to my mods and put a number to them i don't want to cry hahaha, it's amazing to see how much money we can spend in mods without even thinking about.
hodge-xj
5.9 cummins
No joke, that's why I've been dabbling with used tires and selling them while they still have life left, I didn't want to buy 1000$ in rubber to be unhappy or stuck with something that didn't work. I'm looking at simpler mods now, this bumper and new tires are gonna be some of the last big purchases for a while (aside from a tune that the diesel settlement is paying for).
Track bar, muffler delete, little things I can do, but man I gag every time I think about how much I've spent on things, this truck included. I'm trying to prevent the snowball effect with this truck....so far, not good.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Aighy I got it done. Only thing left is to connect the license plate light but I'll do that tomorrow.
Taking the bumper down is as easy as removing 6 bolts.
32758032637_de2c5dee2c_h.jpgUntitled by RAM RSM, on Flickr
Took me more time find out why i had some groomets in the bags and a couple of harnesses that i guess will be used if i had rear parking sensors. Install is just 4 bolts and it'll help to have a jack to help you line the bumper straight.
The license plate doesn't have a harness so i guess i'll have to splice one of the fatory harnesses and hook up the wire in there.
47648197592_2c4aeb2d6a_h.jpgUntitled by RAM RSM, on Flickr
46785121865_72cc101d7a_h.jpgUntitled by RAM RSM, on Flickr
46785121735_6abf705916_h.jpgUntitled by RAM RSM, on Flickr
Goose_1327
the Bwoody is thicker, hard to tell if it's soild or not but the stocker is definetely hollow and if you grab it in the middle with you hands you can feel.see how it twist, kinf of crazy to think it's so whimpy considering this are trucks with a 10k lbs towing rating. the new one is a lot more solid and you can't flex that ***** like you can with the stocker.
Final product
Good to see there aren’t any clearance issues with the BWoody track bar, makes me wonder if Core4x4 track bar needs the optional bend.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
I used this light for my
i haven’t measured but it looks like 1.5-2” clearance by the naked eye. I’ll see if I can take some measurements today to make sure but it definitely clears without any issues.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Got the tire carrier installed, Thanks @revitupmoto33, Got it primed and painted with Rustoleum semi gloss black.
46849332415_8680f79500_h.jpgUntitled by RAM RSM, on Flickr
40799571313_8cefa3d1ae_h.jpg2019-05-03_10-46-10 by RAM RSM, on Flickr
40799444893_a5f0bdbe17_h.jpgUntitled by RAM RSM, on Flickr
Stance with 300lbs permanently in the back, still 40 1/2 rear, 39 1/2 front
46849332885_626168ee53_h.jpgUntitled by RAM RSM, on Flickr
46849331545_d3fbbf4071_h.jpgUntitled by RAM RSM, on Flickr
revitupmoto33
Flagstaff
Ecodiesel
Looks so good paired with that rear bumper :waytogo:
I’m glad there weren’t any issues getting it to work with your topper.
Arturo Rojas
