2014 RAM 1500 Express Crew Cab
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
I can still mount it when needed. The combo is couple of lbs lighter, and when needed i also the 3rd breake setup plug and play :)
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Today i ordered some maintenance items.
I had to check a video on how to change the spark plugs because apparently is a little complicated with the Hemi. Doesn't seem worst than changing the spark plugs in the Pentastar, haven't cursed that much changing damn spark plugs since my 99 Camaro, then my 13 Jeep Wrangler Unlimited, so i guess i'll have to see how is it going to be with the Hemi :)
16 NGK 92145 Spark plugs from Rockauto
and some sort of special socket from Amazon https://www.amazon.com/gp/product/B0014ZVSVK/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Also i think i'll pay my local lube place to get the trans fluid changed. I can change all the fluids in my truck, but never done the trans before and that one seems quite a bit messy. I think with the 2 filters and the fluid i'm looking at $100 if i do it myself, or $200 if i let the dudes at my shop do it. Nothing to clean with the last :) so i i'll check it out tomorrow.
hodge-xj
5.9 cummins
6 or 8spd?
Sent from my P00I using Tapatalk
hodge-xj
5.9 cummins
6, I picked the filters from the dealer this afternoon for $74
I need to do mine but it's the 8spd and word is it's a whole new animal to change fluids. Was hoping you'd guinea pig it for us [emoji41]
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
I keep telling myself I need to have that fluid replaced as it’s the only I haven’t done. Truck has 77k miles now.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Truck is in the lube shop getting the trans fluid replaced. $370 OTD more than what i was expecting to shell out but what that heck. I shouldn't have to touch it again for a long time knocking on wood.
hodge-xj
5.9 cummins
But you didn't even have to get dirty. I loathe doin tranny services. Never fails there's always enough fluid hiding somewhere you end up wearing it.
hodge-xj
5.9 cummins
That's not bad at all!
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
I wasn't expecting 16 mpg on 37's :), i'm still scratching my head on this one. Technically i have lowered the effective gearing to around 3.55's, but the tire is a lot bigger and heavier than stock. heck i'm about 1-1.5 mpg better than what i used to get with the Falken 315's in this same route. MPH measured and verified by GPS and verified with those mobile mph stations you see in certain spots around some cities.
hodge-xj
5.9 cummins
What's the weight difference tho. And rolling resistance. 2 factors that are hard to calculate effect of but I'm sure play a huge part.
4eyedconekiller
North MS
EcoDiesel
Hodge, if I lived closer, we could do an ATF Change Party!
Wait - I ain’t touching the new trans in mine - gonna let the dealer handle it for at least the next 100K lol
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
According to Falken Website the 315's were 72lbs, according to BFG website the KO2's are 69lbs.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
New fog lights
48419379622_ffb996e1c8_h.jpgUntitled by RAM RSM, on Flickr
i'm still waiting for the H10 to DT harness before i get them installed, but ill go out right now to at least configure the fogs with Alphaobd to tell the BCM i have fog leds in place.
Enable Fog light leds
Select vehicle, body computer, 2013-2017 body computer
Then active diagnostics
select procedure Car configuarion change (should be all the way down to the list)
CBC Features-LED Front Fog Lamps present - Set to Yes, default should be no
Finish
And
Enable Fog light switch high beam
CBC Features-Front Fog Lamp Dropout Enable - Set to no so they fog lamps can be enabled with the hi beams - Default Yes
Finish
4eyedconekiller
North MS
EcoDiesel
I’m anxious to see how these pan out. Not sure how deep I’m gonna get with the stock fogs as they are so Deeply set into my bumper.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Ok so i got the new H10 to DT harness, and i took my old Fog wiring harness from my factory bumper out so this should be a complete plug and play install now :)
The factory fog wiring harness should be Mopar 68197065AA, $32 from the dealer
48419671636_8f46d14d3a_h.jpgUntitled by RAM RSM, on Flickr
