pope3909
This all started out of nowhere. Any idea what would cause these system wide failures? The PCM, TCM, and ABS all have failures. This is causing the vehicle to stall and/or shutoff, or not start at all. I'm weary of taking it directly to the dealership because I don't want them to have to go through $5,000 worth of unnecessary parts before they get to the actual solution. There are a couple of more codes, such as EVAP leak, but that problem has been off and on for years. The dealer was supposedly supposed to fix it with a recall but it just came back.
P2305 Ignition Coil 2 Secondary Circuit - Insufficient Ionization
P2302 Ignition Coil 1 Secondary Circuit - Insufficient Ionization
P2323 Ignition Coil 8 Secondary Circuit - Insufficient Ionization
P2311 Ignition Coil 4 Secondary Circuit - Insufficient Ionization
P2308 Ignition Coil 3 Secondary Circuit - Insufficient Ionization
P2317 Ignition Coil 6 Secondary Circuit - Insufficient Ionization
P1B14 Park-By-Wire - Unintended Park Position
U1424 Implausible Engine Torque Signal Received
B21DD-84 System Voltage : Signal Below Allowable Range
B2199-16 Battery Voltage : Circuit Voltage Below Threshold
U103C-00 KIN/IGNM Communication : No Sub Type Information
B1A8F-00 IGNM Photo Sensor Failure : No Sub Type Information
B21DD-16 System Voltage : Circuit Voltage Below Threshold
U0415-00 Invalid Data Received from Anti-Lock Brake System (ABS) Control Module "A" : No Sub Type Information
U0121-00 Lost Communication With Anti-Lock Brake System (ABS) Control Module "A" : No Sub Type Information
