DeputyChef22
I’ve searched the threads here and found no definitely answer to let me pick your brains.
I have tried Fahren Termitor brand bulbs (my favorite and ran them in my 2006), with a quality decoder. Had no lights or an occasionally flicker but absolutely no steady light output.
I reverted back to Lasfit bulbs, less bright but doable, still connected to the decoder. Same results.
Removed the decoder and wired them straight with absolutely zero difference.
I keep getting told and reading that a lot of electronic things changed in the 2015’s and that I’d need resistors for the headlights or AlfaOBD. Alfa is obviously new to but I’m learning slowly what it does. I’d rather wire in a resistor but I can’t find something just screams “this is it!”
So any guidance or advice is always appreciated.
The high beam LED Fahren Termitor 90° bulbs work flawlessly. Should even try doing the 90° for the low beams? And am going to run into the same ****uation with the fog lights?
Thank you!
Thank you!
