Sparty96
Ok so Wednesday morning I jump in my truck to go to work. The check engine light pops on. I noticed the oil temp gage seemed to be slow coming to temp. I scrolled the the menu and saw the temp was coming up. In a few minutes of driving it was in the normal range. I picked up a obi scanner and it said i had a large evap leak. Cleared the code, restarted engine, all was fine. Drove to work this morning with no issues, its an hour drive btw. As i left work the check gas cap light came on. When i stopped i took it off, put it on, still on. I dont have an odometer reset button like my manual says. I reset both trip a and b. Still on. Cleaned cap and filler, put some light grease on seal which is still fine. Its still on. Truck has 65,000 miles. I read somewhere people are having fuel pump replaced?
