thebanjoman
I have a 2016 RAM Express Quad Cab w 5/7 I bought in 08/2019 with 26K Miles on it.
No modifications to the truck.
It's now got 34,884 on it and I changed the oil at 30K. I do 5K oil changes because I've always done it so its due.
It's been a good truck, suits my needs but in the last few days now that it's getting warmer around here in Virginia (80 today) I noticed on two separate trips that the temps are creeping up past what I feel comfortable. as high as 212. The temp needle never goes past 1/2.
Temps have been running 197 - 204 all the time, except for the last 2 days of going out.
Yesterday I ran an errand and on the highway at 70 the temp rose to 212. I was headed home only going a few miles and backed off the speed and the temps went back down to 201 at around 45 mph and I got home. I let the motor cool and checked the radiator.
Well it never noticed it since I got the truck while that driving and checking my oil that the overflow tank cap was not seated properly. It looked closed to me until I touched it and saw that it was never seated properly since got the truck.
I pulled the overflow stick and the tank was empty. I opened the radiator cap and it was still full and I could see fluid at the level it was supposed to be.
I took another vehicle and got some antifreeze, made my 50/50 mix and filled the overflow back to the max level. I made 100% sure the overflow cap is closed and seated properly now. That plastic overflow cap is GARBAGE,.
Today i took the truck out running another errand through town not going over 50 and the temps never got above 202. UNTIL I took it out on the highway and got up to 70. and the temp AGAIN "creeped" up to 212. I backed of the accelerator and coasted while I was getting off at my turn and the temps came back down and I drove the 1 mile till I got where I was going.
Somethings going on here and I'm trying to understand what I could be. Seems like I can run around town and be OK but now temps go up on the highway.
I did the usual, check for mud/dirt/bugs in the radiator fins. Fan clutch seems OK but Im truing to wrap my head around this.
Truck has never given me a moments trouble I've been searching the forum and the Internet to see if there is something similar to what I've been experiencing but have found nothing.
Don't want to take it in unless I have to, I want to try and understand this more before I do.
