2016 Ram transmission
agricon
Back last summer I bought a new ram 1500, noticed 3000 miles in I had a transmission oil leak on my shop floor, took it to the dealer for it to be looked at, anyway long story short 3/4 of the oil leaked out of the transmission also resulting in some choppy shifting. Took it in, they said the fitting on the trans cooler was leaking from the factory and I likely ran a few thousand miles with very little oil. I asked if their was possible damage and the service manager said don't worry about we fixed the leak and put new oil in there will be no damage possible.
Fast forward to today, I did my first oil change myself given I am fed up with local dealers answer to my possible damage question. took a look at where the transmission case meets the engine and noticed some trans oil there sitting on the surface see attached pic, is this normal on a new truck with 10k miles? No dip stick of course to check oil level, another pet peeve on mine on RAM. I am wondering if the main seal is damaged, might explain the weird noises too before bringing it to the dealer.
yillbs
There should never be transmission fluid on the case...even more so at 10k miles. I'd take lots of pics, and continue to take it in. Keep taking it in until it's fixed.
averageguy
Belleville Mi
hemi
If its not the front seal in the trans I would say rear main seal in the motor. Take it the dealership regardless because it shouldn't leak anything.
RamCares
n/a
n/a
Hi agricon,
I'm happy to provide any additional support you may need in taking your vehicle back to the dealership. Please let me know if I can assist.
Kori
Ram Social Care Specialist
Rkunzer1
Trans
How can I find out if I have the 6 or 8 speed trans? 1500 Tradesmen 5.7 V8 hemi.
yillbs
What's your vin, we can take look based on that, more over, if you have the + and - buttons on your dash, just press the negative, then press the + until you don't see numbers any more, whatever the last number you saw was, is the number of gears you have.
Although, the vin might be the best bet in your situation .
Rkunzer1
They don't use the three speeds anymore right?
yillbs
No, it's been a while since those have been used in any truck / car from FCA.
In fact.. I think the last one was in the 1970's. the 2500/3500 had a variation of it a while ago, I think it was in the V10, none the less, it's been a while... Jesus man, where have you been .
Rkunzer1
I looked up the vin on another site. It said 3 speed transmission. Lol. I just want to know tow capacity and what the optimum weight would be.
yillbs
Well, if you give me the vin, i'll happily tell you. I'm assuming you'll have the 8 speed if you just got it last year, but not knowing what the year of the truck is, the gearing, cab size, bed size, it's hard to tell you much of anything. No one can do anything with your vin, it's just an identifier of the truck, it's completely safe to share it in the open.
yillbs
If you have the dial shifter on the dash you have the 8 speed. If it is a column shifter or console shifter it is the 6 speed.
haha, ^^ there you go. that's probably the easiest way to tell, my way was considerably more overly complicated :puke:
Rkunzer1
Thanks. Got the dial. 8 speed better for towing?
Rkunzer1
I'm at work atm. I'll shoot it out later. No rush. Going to rv show in February. Don't want to look like I don't know what I'm talking about. Hope it doesn't show too much.
averageguy
Belleville Mi
hemi
If you do some searches in the towing and hauling section there are a ton of threads with the info you are interested in.
Markks
2016 Express RCSB 4X4
Pentastar
Back last summer I bought a new ram 1500, noticed 3000 miles in I had a transmission oil leak on my shop floor, took it to the dealer for it to be looked at, anyway long story short 3/4 of the oil leaked out of the transmission also resulting in some choppy shifting. Took it in, they said the fitting on the trans cooler was leaking from the factory and I likely ran a few thousand miles with very little oil. I asked if their was possible daSmage and the service manager said don't worry about we fixed the leak and put new oil in there will be no damage possible.
Sorry about your issues... But keep us posted, I've noticed a little bit of oil on the garage floor where I park my Ram.. I have not crawled under to check the tranny, I'm afraid with all my other problems, I've got a bad tranny too.
Tach_tech
5.7L HEMI
What's bad about your transmission?
barr0208
winnipeg manitoba
2019 ram 1500 sport long bed
5.7 3.92 4x4 ruby red
no damage running with low tranny fluid yeah sure and after your warranty is up and it fails mmm I would be trying to get new transmission yep.
Reticle918
