Kuhndog970
You better make sure you are getting a hemi g56. The cummins version won't bolt up and the input shaft is different.Oh they did make one for the 5.7. I somehow overlooked it... But it's $1k if you're referring to SD2-1022R-45 and it's a stage 2 clutch. I think I'll save $700 and stick to my K70351-01 anyways.
I'll go to the junkyard Friday to pick up the G56, hydraulics, pedal assembly, floor console, mounting bracket and flywheel. Work officially begins next Monday and I'll post updates here. Let me know how the fuel line problem goes because I'll likely run into the same issue.
