2018 2500, prewired for remote start?
tejasmikey
Dfw
A70CFF97-7B46-4F51-9173-8C3FABC01A3E.jpeg DFD4ABE0-0ACC-4857-A35E-ABBDFBD9C569.jpeg 52A4E952-6EA2-4DCD-9274-A436BA36F4A5.jpeg Hoping for some help, looking to add remote start to my 2018 2500 6.7
Looked at the thread about 2017s but I’m not great with wiring so I’m hoping someone can tell me what I’m looking at.
Here’s front and back of underhood connectors as well as connector by the brake pedal, looks like everything’s there? Should just need a hood latch and programming if I’m reading things right.
Thanks for your help!!
1500ram12
5.9L Cummins
View attachment 170278 View attachment 170279 View attachment 170277 Hoping for some help, looking to add remote start to my 2018 2500 6.7
On the 2017-18 you technically only have to ground pin 11 on the bcm (I'll have to look to see on which connector), buy new key Fob skins for your current fobs because they are already have the same board as fobs with remote start on them just need the contact on the skin, and use alphaobd to enable remote start.
2018 2500 6.4L
T
tejasmikey
Dfw
2018 2500 6.4L
Found your stuff on the original post, thankyou for it all!
Trying to figure out if I can get away with just the latch or if I need to buy the while wiring kit.
1500ram12
5.9L Cummins
All the remote start kit comes with is the latch with a wiring harness that contains 1 wire that goes to pin 11 that tells the bcm that the hood is shut (grounded) and 2 fobs. So by grounding pin 11 you can bypass adding the hood latch and buying the skins for your current fobs you don't have to buy new one's. Had I known all of this before buying the kit I would have gone this route
2018 2500 6.4L
Reefer
Louisiana
2018 2500 6.4L
Can someone tell me where to find this pin 11?
1500ram12
5.9L Cummins
Under your dash in a very fun and accessible area you'll see this. On the door side above the emergency brake. You'll want C1. Circled in Red
Then in that connector you want pin 11
2018 2500 6.4L Tradesman
Reefer
Louisiana
Thank you, that is the pin I need to ground to bypass the hood latch to trick the bcm into thinking the hood is closed correct?
Reefer
Louisiana
Also when programming in alfa since I'm grounding pin 11 do I still select 1 ohm resistance? Also do I unpin 11 tap and ground or do I leave it and tap it then ground?
1500ram12
5.9L Cummins
I believe it's the 1k but if it doesn't work try the 500/500.
In the alphaobd thread on page 1 look for my name and open the Google drive link. I have step by step instructions with pictures on how to enable remote start
Lawsuit11
Fort Worth, TX
It’s 500/500 for the hood adjar usage setting
1500ram12
5.9L Cummins
It’s 500/500 for the hood adjust usage setting
I know if you use the oem remote start kit it's 1k
Lawsuit11
Fort Worth, TX
I installed my hood latch in my SLT and ran the wire from the Connector under the fuse box to the bcm and I have 500/500 enabled and everything been working good since November.
1500ram12
5.9L Cummins
Maybe it doesn't matter or might be year based
Reefer
Louisiana
[QUOTE="******, post: 2071981, member: Also do I unpin 11 tap and ground or do I leave it and tap it then ground?[/QUOTE]
Thanks for the help thus far...What about this?
Reefer
Louisiana
I went through all the steps for setup, I hit the remote start button twice, horn beeps, lights flash, but that's it, doesn't start. Any ideas?
1500ram12
5.9L Cummins
It's going to need a couple of key cycles and maybe a short drive.
Reefer
Louisiana
I went to cycle the key and when I got in it says remote start cancelled hood open. I guess where I grounded the pin is a bad spot?
1500ram12
5.9L Cummins
Possible or may need to change the ohm setting
OasisNinjaBat
