2018 Dodge Ram 6.7 engine light
brossco
2018 Dodge Ram Diesel 6.7
Engine light comes on then the Transmission starts shifting hard after awhile the transmission starts smoothing out. ( I assume the Computer is relearning ) I can shut the engine off over night and the engine light resets its self. Next next day I can be driving and it will do the same thing. I took it in to a mechanic to have the code checked out and it showed a CCV code. So I had the crank case Ventilation filter changed and it worked for a couple days and now its doing the same thing. Any Advice will be thankful!
OC455
Central NY
You would have better chance of an answer if you posted this in the 4th Gen forum. This section is for nominating and voting for truck of the month/year.
