2018 model hemi operating temperatures
shellj22
texas
I have 2018 hemi, what is the normal oil, water and transmission temperatures at 90F?
Oil 225f
water 204f
trans 190-210f
Assuming long trip, not a lot of load, which can go higher.
caulk04
Supporting Vendor
Cruising highway at 70~, figure 197-203 engine, 180-190 trans and 205-220 oil.
S
shellj22
texas
Thanks looks like my hemi has normal operating temps. I know some are concerned about radiator temp and are replacing thermostat with cooler one. Still thinking about that
Ridgerunner665
US
My advice... don't change anything if you've got warranty left.
And even after that, be very careful following online advice... I'm not saying some of it isn't honest, but a lot of it isn't well informed.
Sent from my SM-G986U using Tapatalk
texan279
Houston Texas
I'm in south Texas. Summer's here are 105+ daily for weeks at a time. Plus, I drive in stop and go traffic everyday on the way home. I did switch to a 180 tstat couple years ago, kept it about ten degrees cooler. Definitely tell a difference driving in cooler Temps vs. hotter Temps.
S
shellj22
texas
Have u found any negative effects of having changed out thermostat?
A 180 might trip a code if your truck is untuned,but you can get away with a 190 thermostat with no issues on a stock truck,it's a little better then the factory 203 thermostat for your conditions.
S
shellj22
texas
A 190 thermostat would definitely cool down the water and oil
In Texas you really need to get the thermo bypass the hell off your truck, when they clog they fail and there goes transmission. Much more important then the t stat. Engines can handle 225f all day every day, transmissions can't.
PoMansRam
East Aurora NY
Here's a snap of the display on my 2019 classic hemi I took on an 80degF super humid day aftera bunch of use:
It won't bring the oil temps down as much as you think though. If you want your oil temps to drop a bit,you can do a remote mount filter,that'll help bring your oil temps down slightly,you can even do a dual remote filter set-up,which will take close to 10 degrees out of your oil temps,and give you close to another extra quart of oil. And as Burla stated you can get rid of the trannies thermostat.
I started with a single remote filter,then after a bit switched it up to a dual filter set-up,and that's when i had a noticable drop in oil temps,compared to the stock set-up.
Another thing you can do is switch it over to gold plated Redline 5W-30,which seems to have some success with keeping the cam and lifters alive in a Hemi
PoMansRam
East Aurora NY
I know this topic gets kicked around often, but you wouldn't think Ram 1500 hemis would heat the oil the way they do given they hold 7 quarts and all have an oil filter base oil cooler from the factory. Maybe it was the same back in the day with the older V8s and we just didn't know it.
The oil pre-heater/cooler is relatively new,introduced on the later trucks,i think 17 was the first year for it.
BlownGP
Houston/Baton Rouge
I run a 180 in my 2018 (no tune) and it brought the temps down significantly like I knew it would because I've used them in many vehicles
My highway temps at 78mph
are
Coolant 185
Oil 200
Trans 185-190
I had one in my 09 for 7 years with no issues. It did have a tune so coolant never got over 190 and oil actually ran a lot cooler than my 2018..
Trans was always under 165 but it was a the 5 speed.
BlownGP
Houston/Baton Rouge
So, the trucks have a oil heater too.. That makes so much sense, because the oil warms up so fast in my 2018 then it did in my 2009.
My 2009 would take at least 10-15 minutes of driving before it even got to operating temp.
The 2018 seems like it's at 190 in less then 5 minutes. I thought something had to be difference with my 2018 because even after the 180 T-stat it still did it.
Now I know, man why can't they just leave **** alone. lol
You want to know what's really funny,the 5 th Gens apparently use coolant to heat the diff fluid now to,lol
Bramo
