2018 ram 1500 junk
armymp1130
armymp1130
Rhode Island
well everything is tight for sure, and im not sure why my sway bar link is tilted but your sway bar link is different than mine
ryan russell
Springdale Pa
I put a Ford link on mine it's shorter for the lowering kit. I don't think it's any part of your problem but was just pointing out it looked odd. But being you set them to lift the front that's why yours are at that angle
armymp1130
armymp1130
Rhode Island
well i also added the suspension max end links for the level, but the ride today with the factorys was good there was such a small small vibration but was mostly smooth
Texjim
Terrell Texas
Did these problems exist prior to the mods when the truck was stock?
armymp1130
armymp1130
Rhode Island
the only parts is the bilstien 5100 infront but i had a 2015 ram that i had bilstiens on and that truck was a dream, rode amazing, so i put same kit on this truck and its awful the truck is garbage, its clunks in the transfer case, when i jack rear up and turn rear diff theres play that creates a clunk in transfer case.
armymp1130
armymp1130
Rhode Island
CV joints shouldn't be loose. I think you found your problem. There should be some play in & out a bit, but if it is loose like you are describing, that would cause the vibration at the upper speeds.
the play was on the side that goes into dfiferential you could push up and down on it
FF1899
Syracuse NY
Following this one. If it drys up tomorrow I'll go check my shaft and see if does the same thing or not
alphaprojects
