2018 Ram 1500 TPMS
Donald L
Just got my Ram and have my first question. Can I dislpay my TPMS screen just to look at the pressures the sensors are reading? Id like to compare them to an actual gauge.
pedersen_tim
US
Depends on your model of ram
pedersen_tim
US
They are generally pretty accurate in my experience. It might be a couple psi off maybe 3 max
R.L.K.
Bristol , Tn.
Yes Sir you can [emoji106]
Utilizing the up , down , right & left buttons on the Left side of your steering wheel access the Vehicle Information screen using the up or down button , then go left or right untill the TPMS screen shows up [emoji106][emoji2533]
Know this Sir. If you adjust the tire pressure up or down it may not reflect on the TPMS screen untill a short drive .
On my 14 Ram the recommended psi is 39.
Hope this helps [emoji16]
D
Donald L
Thanks everybody I found the screen. Im going to pickup a new gauge and post my compairson
buddy guy
alberta
i've been told on any vehicle, tpms should be treated as a guide not a bible. I trust it more to give me forewarning of a seriously low tire that triggers it, than to look at it and go pressures are good, don't worry about a manual check.
co-pilot
houston,tx
Can the sensor be calibrated to the correct setting?
noraa73
