Jose Pineda
- Apr 9, 2021
- 11
- 5
- Location
- Houston, TX
- 2018
- 3.6 Pentastar
Good afternoon, I just got a 2018 Ram 3.6 V6 and am having issues with it running hot. Coolant temps will fluctuate on the highway between 212F-242F whether I have the A/C on or off. I get the high temps with the A/C on the coldest setting but as soon as turn the temperature dial one setting over to get coolant flow to the heater core temps drop sharply to 190F-203F. Here's what I've done to it:
- Checked coolant levels, radiator and expansion tank were full
- Pressure tested the system and was able to hold pressure
- Replaced thermostat and water pump (overheated due to stuck thermostat)
- Bled all the air in the system via the valve on the thermostat
- Flushed heater core (currently having issues with water sloshing sound inside, heater works)
This may sound like a situation where I still have air in the system but as soon as I turn on the heater, coolant temps drop down to normal range and stay there. Previously I had air in the system and even with the heater on temps would go up beyond 235F. That has not happened since the last time I bled the system. High temps only happen with A/C on coldest setting or with it off. Previous owner did say that he put some Bars Leak head gasket repair and drained all the coolant before refilling the system. I have also block tested the system and it did not show any combustion gasses. Any ideas what could be causing these spikes?
Thanks in advance
Thanks in advance
