littlebiscuit
Hi am new to these type of information type websites. Recently traded Ford F250 superduty for 2018 Ram 3500 Tradesman 6.4L Hemi DRW. My question after doing quite alot of reserch I installed the OEM bed lighting in truck and activated with AlphaObd. Then found that the is a switch that controls them from a switch also under Driver Side Light. The truck had pigtails with connectors all ready for lights. what I am needing info on the switch wiring? found another pigtail attached to one on drivers side but no connector attached. So i took the harness that came with the light cut off connector and attached it to pig tail. I purchased the switch for the light and am wonder if that pigtail is correctly attached at The right pin on BCM? I did hook a meter to connector verified had 12volt approx the lights came on but went a way when lights timed out. Does that sound right for the operation of that connector when i plug the switch into how will it get power if voltage isn't present all the time? Thanks for any help or explantation.
