2018 RAM Security Module Bypass
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
Now taking orders for RAM 2018 Security Module Bypass Harnesses. If you have a 2018 RAM and would like to perform diagnostics or make changes to the modules of your truck using tools like AlfaOBD or AutoEngenuity, this bypass is for you. Cost of the bypass is $50.
Can I use this on multiple trucks?
Yes. We have sold several of these already to dealers and third party shops who work on RAM trucks. If you are planning on using the bypass on multiple trucks, let us know and we can customize it so that it is easier to use on a temporary basis.
I am looking for something that will allow my Innova code reader work again and maybe in the future a tiresize adjuster. Can you elaborate on the "easier to use on a temporary basis" customization.
Thanks in advance
Sonoman98
Gillette Wyoming
6.7 cummins
I lost my install instructions can someone please send me the link or just tell me where the connections go?
KSH
EcoDiesel
Bypass cable worked great!
Scar1331
Dallas
Ok purchased the Security bypass module, do I still need the bluetooth OBDII ??
Any recommendations on a android device? will a fire tablet work ?
DeereGuy
DeereGuy
Pittsburgh, PA
Yes you will still need a Bluetooth. I think a fire tablet will,work but you may have to load it differently. I am not totally sure. Check out the first post in the following thread and if you have Alfa questions there’s lots of good knowledge over there. https://www.ramforum.com/threads/alfaobd.123982/
Scar1331
Dallas
Team, I have my 2500 security harness - its has 1 green one white do I need to plug both in??
KSH
EcoDiesel
Yeah. Look at the colors of the other connectors and plug them in the same place so the connector are all the same color.
1500ram12
5.9L Cummins
If I remember right green plug goes to the white connector harness and the white goes in the green
Mpgrimm2
SC
5.7L
As mentioned, to will need to plug both in.
You should have gotten a link/code via email from DeereGuy with your purchase/shipment info to download the directions.
M² Mods.
Jus10case
