2018 RAM Security Module Bypass
Colt45automag
Mendham, New Jersey
6.4L HEMI
I've just installed this bypass in my 2018, 2500 today & now my tire pressure is 55psi all around. A true miracle, thank you!
Lawsuit11
Westland, MI
They build them by order if I remember correctly.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
See link on the OP to place an order with DeereGuy/ Mike D. (the other Mike). Not sure what his current backlog is like.
Mike G.
M² Mods.
Chino Valley, AZ USA
2019 Classic Crew Cab
I saw this question asked further back in the thread, but did not see an answer.
Is this harness required, and will it work, on a 2019 RAM 1500 Classic, Big Horn, 5.7?
RodeoGeorge
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
RodeoGeorge
I would like to know this as well... so we neef the AlphaOBD software... the OBDlink MX and security harness?
Sent from my SM-T387V using Tapatalk
Lawsuit11
Westland, MI
Thank you.
I thought that was the case, but better safe than sorry.
RodeoGeorge
Yeah in 2018 FCA decided to make it harder for everyone to access all their vehicles settings by adding a security measure to the OBD2 port so only authorized personnel could change truck info/settings.
All he needs is your truck info, make, model & year and he will make the correct security bypass to get you rolling.
mcryder
Orlando
2019 Classic
So I don’t feel like dropping the coin on alfaOBD, an OBDlink and the security harness for my 2019 classic, what combination of high and low beam leds with decoders/anti flicker adapters have been working for anyone.
krakaman24
2018 Ram 2500 6.7L CTD
Colorado
CTD 6.7L
You'll probably end up spending less in the long run going the alfaOBD route. It offers a ton of other features. I have to say I'm very happy going this route. In my previous truck I went the resistor/decoder route and it was much much easier and cleaner just simply changing a setting in the computer.
Sneeper69
Colorado
Cummins 6.7
I haven't seen this question yet after searching this thread. Can you just go to your dealer and get the code for the 2018 or newer trucks? Is it just one code or are there different codes for different things? Basically, do I really need this harness or can I get the code for free?
After posting this I found the topic that answers it. Basically the dealer won't give you the code, am I right? I guess some of the things you can do could void your warranty mabye?
1500ram12
5.9L Cummins
The 4 digit pin is only for the rf hub. It won't do you any good having it if you don't have a way to communicate with the truck. The bypass harness doesn’t get you the pin. FCA added a security module in 2018 blocking access to any of the truck's computer's and modules as a anti hacking feature. The bypass harness does exactly what it says and bypasses the module. Even dealer's can't access certain things with approval. This harness allows access through the obd2 port to access the truck's computer's allowing changes. The only thing you could do is brick your truck to the point where a reset by a dealer couldn't be done. And depending on the dealer may not "warranty" a reset if you do mess something up that backtracking with alphaobd couldn't fix. Depending on the dealers they may give you the pin for free of charge, or they may charge or say they are not allowed, which is a lie. If they want more than $15 there is a app called Chrysler pin puller that can get it for $15.
2018 2500 6.4L Tradesman
mcryder
Orlando
2019 Classic
No doubt, was getting that feeling. Just worried about messing something up and potentially voiding warranty
Sneeper69
Colorado
Cummins 6.7
Thanks, I sent in today and got the code with no problems. Guess I need to buy the harness now.
GeorgeC
DFW
Is 2019 RAM 3500 a classic or new?
Will this bypass work?
DeereGuy
DeereGuy
Pittsburgh, PA
It’s a 5th gen. I make a bypass that will work on the 5th gens and I’ve sold several of them. Proceed with caution using tools like alfaobd because I’m not sure how much has actually been tested on the 5th gens yet.
michael harpe
U.S. Army 2001-2014
quitman, ga
2018 Power Wagon
6.4 hemi
My harness is on the way [emoji16] thanks mike
Sent from my SM-G960U1 using Tapatalk
Jimmy77
Québec
Hi,
I would like to use HPtuners on my 2018 REBEL, do you think your harness will work ?
Thanks.
bbramer0820
