2019 4x4 - Bad Front Axle
GilR
Fort Lauderdale
My mechanic showed me the play in my right front axle. My truck only has 53K miles. Dealer wants over $800 to replace axle. Anyone else had this issue? I do not have extended warranty. Here is pic from another post that looks identical to mine.
Scottly
Safety Harbor, FL
HO 6.7 Cummins
My mechanic showed me the play in my right front axle...... Dealer wants over $800 to replace axle.
My question is as follows: "My mechanic" showed you the issue, yet you called a dealer to inquire about replacing it. So, is "my mechanic" not capable of replacing it? If not, then maybe "my mechanic" mis-diagnosed it while doing the cheapo oil change. If you haven't been to the dealer to have it diagnosed, that might be a good first step. If you have, @DILLIGAF had a great solution. But I suspect that isn't an option because I sense you're not a DIY'er.
G
GilR
Fort Lauderdale
Yes, took it to dealership thinking it may be under warranty. Fortunately "my mechanic" is capable. Not sure where you get cheapo oil change from. I am a DIY'r for some things, but don't think I'll take this one on.
NJ4X4
South Jersey
I was wondering where the "cheapo oil change" came from too.
@Scottly you might want to keep the conversation to the topic and facts presented as embellishing the response with your own "facts" could be deemed as attacking another member... that's frowned upon on this forum and you've been warned about this before.
G
GilR
Fort Lauderdale
Why isn't under warranty? That should be covered under your powertrain warranty. 5year, 60K. I just had my right side and differential replaced 3 weeks ago, under warranty.
I thought it would be covered as well under powertrain. I will call other dealer & see what they say. Keep u posted!
G
GilR
Fort Lauderdale
Thanks!
G
GilR
Fort Lauderdale
:happy160:
jmc921
Dallastown, PA
5.7 L Hemi
Turns out, the front axle is covered under powertrain warranty - called another dealer & they confirmed; Spoke to GM @dealership who wanted to charge $800 - Advised him I won't be going back there again...
Good for you. No need to spend money at dealers who are, let’s say, less than forthright.
