2019 HD Tail lights in a 4th gen
Ram7081
Hurricane 3.0
Well I got everything wired up now. Just put in some temporarily LEDs to get the BSM up and running. Unfortunately there is one issue, every time I start the truck, I get a message saying that BSM is turned off even though it is actually on. Everything appears to be working as it should (at least I can confirm cross path detection was working properly as it was going off as cars drove past my driveway as I was trying to back out). I guess this is an issue related to the 4th gen ‘Classics’ without a solution yet which kinda sucks.
Does the harness work with BSM?
loki223
Spokane, WA
Cummins 6.7
Not to hijack, but since i know @Jimmy07 frequents over here more often then my normal forum, i'll bug him here too. And this is somewhat on topic as well so yeah. I've already put 19 tail lgihts with BSM on my 18, but looking to add the Boost 23+ Tow mirrors onto my 18. Debating between getting 19+ tow mirrors and repinning them, or getting 18 mirrors and adding the BSM wires to them. I'd prefer to go the 19+ method so i don't have to crack plastics on brand new mirrors and have more random mirror glasses laying around that i don't need. But here is what i've layed out on the wiring conenctors, and there are a couple extra wires on the 19s then seem important, but i don't co-relate over to the 18s So wanted Jimmys input. Mostly the switch sense, and sensor ground where they should go on the C1/C2 pins for a 13-18
Door Module
Position
Circuit
Function
2018 SPOT​
C1
P705
HORIZONTAL LEFT SWITCH SENSE
C1
P703
MIRROR COMMON DRIVER
C2-8?​
C1
P701
VERTICAL UP SWITCH SENSE
C1
L701
MIRROR PARK LAMP FEED
PUDDLE?​
C1
NO
C1
L801
TRAILER SPOT LAMP FEED
NO​
C1
L702
TRAILER PARK LAMP GROUND
C1-3​
C1
8
NO
C1
NO
C1
10
L802
TRAILER SPOT LAMP GROUND
NO​
C2
P501
MIRROR TURN SIGNAL DRIVER
C2-9​
C2
C160
MIRROR HEATER RETURNB
C2-3​
C2
P551
MIRROR APPROACH LIGHT
C1-1​
C2
P161
MIRROR TOW POSITION SIGNAL
C1-6​
C2
P593
MIRROR LAMP GROUND
C2-10​
C2
C16
MIRROR HEATER DRIVER
C2-4​
C2
P711
BSM INDICTOR DRIVER
C1-3​
C2
8
P73
C2-7​
C2
P71
MIRROR VERTICAL DRIVER
C2-6​
C2
10
P75
MIRROR HOIZONTRAL DRIVER
C2-8​
C3
G31
AAT SIGNAL
C2-5​
C3
A856
5 VOLT SUPPLY
C1-10​
C3
P65
MIRROR HORIZONAL POSITION SIGNAL
C1-9​
C3
P69
MIRROR SENSOR GROUND
C1-8​
C3
NO
C3
G931
SENSOR GROUND
C3
NO
C3
8
P67
MIRROR VERTICAL POSITION SIGNAL
C1-7​
C3
P694
POWER FOLD DRIVER
C2-1​
C3
10
P691
POWER FOLD MIRROR UNFOLD DRIVER
C2-2​
Also, side bar with the mods here, this seemed like the most relevant thread, but if there is another more popular thread this would make more sense in handing out in, feel free to move
loki223
Spokane, WA
Cummins 6.7
I feel like moving C3-6 to C2-8 would work, and pairing that ground with the P69 circuit?
but that still makes me wonder what the P701 and P705 circuits, where would they need to go for everything to be happy? Maybe the all knowing @Jimmy07 will chime in shortly I could use Boost's wiring box for the spot light (L701) or run my own wire
Arturo Rojas
