2019 Ram 1500 4X4 Quad Cab Lift
Wiendog
Malibu,Ca
2019 1500 Laramie Quad Cab 4x4 6'4" bed
I am posing this question for lift options on a 2019 Quad Cab 1500 4x4 with a 6/4 bed .I have learned the hard way there is a difference.I first installed a Wulf 3 inch front spacer 2 inch rear spacer.I liked the look I did not change the UCA so it was jambing up my stockUCA. The ride was not ideal.Then Mopar came out with there kit.I had my dealer remove the old kit and install the Mopar.I liked that even more.The only problem with that kit in my truck is the ESC traction control keeps engageing on curvy roads.Dealer replaced speed sensors steering angle sensors yaw sensor tried every recalibration.Even escalated to a Star FCA case . I tried a Hellwig sway bar that did not help either. Now finally they are saying there kit is not compatible with my truck and are going to remove it and return my truck to stock.So that is my situation, months of misery so does any body have the same truck as mine or at least Quad Cab with some input.
