2020 bighorn interior lights
VB712
Maxi_built
Va Beach
Just traded in my 2014 for a 2020 bighorn. The interior lights are terrible.
who has swapped to leds? Any write ups, which bulbs to use etc?
qxbuzz
I have a 2019 3500 Big Horn. I used these and have had no issues at all. I only used the map, footwell, and dome lights. The vanity lights were too bright, and I didn’t bother with the glove box light. I did not change anything on the exterior. I have the upgraded lights on the exterior.
The interior lights look real good now, and it is not too bright....
NorthStar1
Rosenberg, TX
2020 Ram 1500 Big Horn/Lone Star 4x2 Crew
Hemi 5.7 eTorque
I did the same thing but utilized Lasfit LED lighting. If you go to their website (or YouTube and search for Lasfit 2019 Ram 1500), they have videos on how to replace all the lights with LED. They made a huge difference.
Go to the following on this forum as it has been discussed before and part numbers are listed:
https://www.ramforum.com/threads/bu...nal-ram-1500-big-horn-v8.152842/#post-2157291
I've had zero issues with them and they are plug/play without adding resistors or special connections.
VB712
VB712
Maxi_built
Va Beach
Went with the Lasfit interior bulbs. Perfect fit, awesome color and super bright. Thanks!
Lil' Rob
Ohio
Can you provide an actual link to these...can't seem to find them for some reason...thanks.
qxbuzz
I was originally going to go with the Lasfit ones, but saw the ones on Amazon. 3 months and they haven’t let me down. Hopefully they’ll last for the long haul.
ToyHaulin
Ocean, NJ
5.7L v8 Hemi® MDS VVT
Are you guys still satisfied with your Fyre Fly and Lasfit LED kits?
I also don't like how the OEM lighting system uses a dimmer to slowly illuminate the interior. If you open a door to grab a tool or something, I feel like you have to wait two seconds before you can see what you're looking for.
NorthStar1
Rosenberg, TX
Hemi 5.7 eTorque
I traded my 2019 Big Horn - for a variety of reasons - for a 2020 Big Horn on Saturday. The first thing I did on Monday evening after work was install the Lasfit’s I removed from my 2019. They have worked flawlessly and continue to do so. I’m very, very happy with my Lasfit’s. I replaced all interior and exterior bulbs with Lasfit and they’ve worked well on the first truck and now reinstalled on the second truck. Great LEDs!!!
See the post by Travis Wilson in the link below for the complete list of Lasfit bulbs required for our Rams:
https://www.ramforum.com/threads/bulb-size-for-rear-turn-signal-ram-1500-big-horn-v8.152842/
(And no, I get nothing from Lasfit but do believe in supporting products that work exceptionally well!)
