2026 memory seats
S
skylaneifr
St Louis
hemi 5.7 eTorque
I have a new one and can't figure out how to save 2 different settings in the vehicle. The driver door no longer has a 1 and 2 and set button. Can't figure out where to set seats in the uconnect either.
British Bulldog
Jacksonville NC
SST HO
You SET seats and memory by selecting 1 or 2 button on drivers door. HOLD down until it says “memory 1(or 2) saved”in the screen in front of you. It took me a while to figure it. Takes a few secs. Saves seats, mirrors etc.
Then, when you press 1(or2) it will return to your saved settings and say in screen….
“Memory 1 selected”
Any ? just ask. They did away with the third ‘save” button and made it the massage seat control.
S
skylaneifr
St Louis
hemi 5.7 eTorque
Read somewhere where your seat had to be set forward at least 2 inches or so to work. tried it and it worked but I am tall and like it all the way back. Possible good for my wife using the 2 setting.
After I got it to work from 2 inches forward I tried to set the height to lower it when I shut the engine off but that doesn.t work. Bummer. My 2019 that I traded in did both up and down and rearward for my wife's setting.
S
skylaneifr
St Louis
hemi 5.7 eTorque
I wanted to set the drivers seat a little higher to see over the taller eTorque hood but have to do it manually because Height does not work on memory. That eTorque generator that is bolted to the front of the Hemi engine is what made the hood higher to see over. 2 belts on the front of the engine. Normal size small one for the water pump only and then a 1 1/2 inch flat one for the eTorque generator, power steering pump , alternator, AC compressor and God knows what else.
British Bulldog
Jacksonville NC
SST HO
My seat goes all the way back for easy entry/exit and then returns to memorised setting. I can mess the whole seat setting up and it still goes back on pressing memory 1 to where I want it. Sorry, that’s all I’ve got!
