20x12 Moto Metal Wheels 962, Shaking
apeck5173
STL, IL side
I have had an issue with these wheels since i bought them. I even bought a new set of falkin at3 305/55r20 tires for them. It got a little better but still really annoying at highway speeds. I have had them rebalanced 10 or more times, Even went to Pure Performance In STL that does lifted trucks. They say its balanced.
Does anyone have these wheels?
What do you guys think about using tire beads. Some people say they work, others say dont do it.
ram1500rsm
Trabuco Canyon, CA
You shouldn’t need to use them at all unless you were running 40” tires. And still some of them will get balanced normally. Did they have them road balanced? Go back to the shop that sold you the wheels and tell them they won’t stop shaking. Maybe you can a try any other set of wheels and confirm the set you have are the main issue.
Joshua Collins
2011 & 2023
6.7 & 5.7
Have they been road force balanced? Only other option i can think of with out dealing with the wheels themselves is to use balancing beads which are hit or miss i have quite a few friends that have really good luck out of them.
Now the more intrusive ideas are they can dismount the tires and put the rim on the machine to check run out. They can also break the bead and rotate the tire on the wheel to find the greatest neutral which will jelp with balancing as well.
shanmccarthy
