2500 Aux switches / upfitter code.
Dennis Gulau
Central Michigan
5.9l, Ecodiesel, 5.7l
I've got a 2018 2500 with the aux switch option.
To program the switches in the commercial settings I need a code. Apparently the previous owner changed the code.
Is there any way other than a dealer visit to reset the code?
Thanks.
D
Dennis Gulau
Central Michigan
I've tried all the "logical" changes, nothing works. Odd, because the switches were not used for anything by the previous owner. Odd that he would change it.
Maybe this is a dumb question, but does the upfitter harness have to be plugged in for the code to work? I have not plugged the harness in yet.
Sandevino
North Texas
HEMI 5.7 eTorque
No, the harness doesn’t need to be plugged in. 0000 is the factory default code for the commercial upfitter config in the EVIC. Pulling the battery doesn’t reset the code.
Changing the code takes effort so if 0000 doesn’t work it could be anything. Last I knew, the dealer can’t reset it either.
