2500 E-Fan?
Sticks2010
Central, NJ
What are the pros, cons of e-fan conversion on a 2500? Engine temp got up to 220 a few times in the past while carrying my snowplow.
WhiteExpress
Midland, TX
You fan clutch should have engaged fully at that point.
I would not advise switching over to electric, but perhaps put a 'helper' electric fan in there.
I've not looked on mine to see what kind of room there is in there, but I'd guess you could fit in a nice 18-20" lo profile electric in the factory shroud to pull through a TON more air at lower RPMs.
Power247
High Point, NC
6.4 HEMI
THere should be plenty of room for Aux fans. I know the CTDs have been adding them to help the AC while idling. While not the same of course but you can't be the first guy with this problem.
sewardmark
Minnesota
I did the v-6 fan swap removed The mechanical fan installed jet 180° thermostat and adjusted fan on off ,mine never comes close to 200 degree, it's a RAM 2500 4x4 hemi 2013 6 speed auto ,I pull, skidders, tractors, camper and a snowplow, hope you figure it out
dogcar3
2012 Power Wagon
My 2012 has a mechanical and electric. Although I think the electric only come on for the a/c. Mine never goes above 212* pushing it as hard I feel comfortable. 75mph up hill towing at 4xxx rpms.
S
Sticks2010
Central, NJ
Thanks for the reply's I'm gonna research it. I"ll let you know how I make out.
