2500 gear swap
Charger440
Pa
2018 ram 2500. 6.4 hemi. I have s 6 speed auto with 3.73 gears. Id like to swap to 4.10 - 4.56. What front and rear diff are in these so I know what I need to buy.
Burla
2010 Hemi Reg Cab 4x4
The 2500 uses AAM axles(9.25 front/11.50 rear), the front diff will be open and the rear could be either open or LSD. The LSD if equiped will be a helical gear type.
C
Charger440
Pa
C
Charger440
Pa
This things gutless and has an open diff one wheel peel..
62Blazer
Midwest
A lot of places you can type in the vehicle model and year and it will tell you what is needed. Otherwise the posts above look correct.
In general I don't recommend going from 3.73 just to 4.10. I have done it on my own truck years ago, and have driven a lot of identical model trucks with the only difference being 3.73 vs. 4.10 gears. The change is so small it's hard to tell the difference....especially compared to the time and money it costs to do a gear change. If you want to really see a difference I would recommend at least 4.56.
C
Charger440
Pa
Alright so what's the best website to buy from. 4.88 - 5.13 ratio seems like it be my best option. But im not sure what the front 9.25 has for avail gears. I've only seen up to 4.88 so far.
olyelr
Kewadin MI
5.13 is available
C
Charger440
Pa
Where have you found this? I haven't seen it for the front 9.25. Im still looking
RedSRT4Me
Scottsdale, Az
2015 CC Sport
With 6speed go at least 4.56.
8-speed 4.56 Max on 37's.
62Blazer
Midwest
One question that should be asked. What exactly are you trying to accomplish? Do you have oversize tires? Just towing a lot? Or simply want peppier acceleration?
C
Charger440
Pa
Im about to put on the 40s as soon as I get a weekend to put the lift on. Its just a gutless pig right now with 3.73s and its stock tire size.
Lemniscate_Mike
