273 v8
pnajera01
Under the Hood
3.9 LA
Just a quick question, will a 1967 273 bolt up to a 1988 LA 904 trans? Thanks for the help!
Rustycowl69
2001 ram 3500
V10
short answer, yes. But the 88 TC has to be from a neutral (internally) balanced LA, like a 273, 318, 340. Not a 360, unless you knock the offset weights off the converter, first. When I say knock them off, please use a cutoff wheel to grind most of the weld bead off, first, before giving them a whack.
pnajera01
pnajera01
Under the Hood
3.9 LA
So itll bolt up but just remove the weights from my torque converter? Do you knw of any other modifications that will have to be done?
Rustycowl69
2001 ram 3500
V10
I don't see an issue. You might have to tweak the kick down linkage. I am assuming you're keeping the intake and carb from the 273, because the intakes are not interchangeable between 273 and all other LA's, as I recall.
