2wd 4wd ?
palerider
Are the body parts the same on a 2wd Reg cab and a 4wd Reg cab ? 94-02
palerider
palerider
fenders , hood , bed , doors ?
Wahrsuul
Central S.C.
Should be. I pulled a fender, hood and core support from a 96 4x4 to put on a 98 4x2.
McBroom
Denison Tx
Hemi 6.4L
Yes they are identical. Only the suspension is different
Blue Streak Pearl off-road
muddy12
Indiana
It depends, 1500 or 25/3500?
For the 1500’s, the gen 2 body style ran from 1994 to 2001.
For the HD’s, they continued the gen2 body for an extra year (94 to 2002).
palerider
palerider
Thanks all If anyone knows both trucks are 1500 The cab on the 2wd is a auto and other is a 5 speed do you think I can swap these pretty easy or not? I guess main thing can I bolt in the clutch pedal to the 2wd cab from the 4wd cab. The 4wd cab is not that bad just needs some new rockers and slight floor work so not sure which would be easier ? 2wd cab is rust free.
McBroom
Denison Tx
Hemi 6.4L
Yes you can. It’s finding the clutch and brake setup. It’s a single bracket that holds both pedals
The automatic pedal is wider than the manual pedal
palerider
palerider
ok so I should be able to use all my stuff from the 4wd 5speed cab to work on the automatic 2wd cab and just bolt it all on is what I think your saying ??? thanks
McBroom
Denison Tx
Hemi 6.4L
Yes exactly
palerider
palerider
Have one more question if anyone knows does the hump in center of cab unbolt or will I have to cut out 2wd floor to make room for 5 speed and transfer shifters ?
muddy12
Indiana
If I’m remembering correctly,
The transmission tunnels are the same, they both have the same large
Hole. There are different “cover plates” that bolt onto the tunnel. Should be able to just swap the cover plates.
EvilSpirit
5.9 Magnum
To take this a step farther - in 1999 they changed the front fenders inner fender support behind the headlamp area for clearance for the second bulb in the Sport package headlamps. 99-01 (02 2500/3500's) can use any year headlamp and Sport headlamp units - 94-98's must modify the area behind the headlamps for the Sport units to fit.
So while the fenders do physically interchange - all years are not "identical".
palerider
palerider
ok thanks both trucks are just 1/2 ton 1500 4wd is a 96 2wd is a 98 I guess I will go for it I will post before and after photos when I get time to mess with the project any more info you all can think of post it up thanks again Ram Heads.
palerider
palerider
well I got the truck it ended up being a 99 so I hope this is still going to work out . It had a rust free body so I hope to make it all come together if not may just Cruz it like it is runs strong and shifts nice.
palerider
palerider
