3/5
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
I'm thinking I would like another inch lower. How do I get that out of my Belltech 2/4 without throughing everything out again?
What's the best way?
MR.REMBERT
Santa Barbara County, CA
I plan on doing the same thing when my kit arrives this week. HOTRODHARLEY posted on another thread he cut the front 3/4 of a coil and the back a full coil to get a 3/5 drop using the belltech kit. And if you look at his...'nuff said!
Jizanthapus
Orange County, CA
I JUST did this this weekend with a Belltech kit. Took a half coil off the bottom of the front, then a coil and a half off the top in the back. You'll need to modify the bump stops as well. I'm banging on mine in the back. The Belltech Street Performer shocks are WAY too soft. You can collapse them EASILY by hand, it's ridiculous.
Lhemi
Lhemi
OKC OK
Did you put your stock ones back on? Soft shocks would not help a wobble issue. Makes me wonder...
Lhemi
Lhemi
OKC OK
What size tires are you running?
Jizanthapus
Orange County, CA
I used the supplied belltech front and rear bump stops. If you don't cut your springs at all and leave it 2/4, you'll be fine. However, if you cut the front and rear, you have to modify the bump stops to accommodate the difference. The front, I removed 2 rings off the stops. The rear, removed an inch and a half which leaves almost no material to bounce off.
275/55/20
Jizanthapus
Orange County, CA
That IS a sweet ass truck. Any issues other than the bump stops? How low did that actually get you?
I didn't measure, I went back and cut more off the back as I hate the raked look. I'd say it's at 3/5.5-5.75. I have problems in the back now though.
Darkflow
Odessa, TX
^^^ Air lift helper bags may help you if you bottom out. They fixed my bottoming out but I also found out I didn't have any bump stops when I installed the bags. No wonder it hit hard at times. Idk if the shop I had lower the truck forgot to install them or not, but the bags alone have stopped it.
MR.REMBERT
*** - Are you just bottoming out or are you having other issues?
I was thinking about doing the helper bags as well. For only 100 bucks, it seems like a good deal especially if it compensates for the lack of travel.
Jizanthapus
Orange County, CA
So far in the back, I've taken 2.25 coils off the Belltech. 0.75 more than what many others have done. I haven't seen any issues like the control arms banging on each other or anything, only thing is the bump stops. Also on the drivers side, removed half of the bracket that holds the rear brake line in place on the lower control arm as it would have hit the upper control arm under compression.
The belltech shocks are too weak. I think even the spring is too weak. Having to add a helper bag is just cheap in my opinion. Not saying people are cheap, saying that if a company sells a kit that is so weak you have to "help it," that's ridiculous.
I personally hate any bag of air on a vehicle, unless you're doing it for show purposes. They leak and have too many potential problems. A good shock seems to be the hassle free fix to me.
$100 for 2 air balloons, $150 for new shocks if you're dropped beyond 3".. Might as well get QA1 shocks for $300 and adjust it to how you like it, one time, and be done.
CrownSuspension makes a 4" drop spring for the back that isn't progressive and looks to be thicker than Belltech / McGaughy's.
2009-2013 Ram 1500 4" Rear Lowering Springs: Crown Suspension Lowering Kit Lift kit
Lhemi
Lhemi
OKC OK
So where can I buy the shocks?
Lhemi
Lhemi
OKC OK
Thanks!!!
joeg45
Katy, Tx
Just here to offer what I've done
I cut 1/2 a coil up front for 3" and 1.5 for 5.5-6ish drop
Bump stops I used the supplied front ones in the back and bought the 1 1/4 ones I think for the front
Shocks I have qa1 all around had to modify them to fit they are not a bolt on ready shock but nothing to extreme just change a couple parts to fit
Cut my end links to reposition the sway bars plan on making/buying adjustable ones one day
And adjusted my pan hard bar a little bit more
All in all rides good
And Mr. Rembret I did coat the ends cut with a little clear coat
Jizanthapus
Orange County, CA
How did you mount the threaded bump stops supplied for the front in the back? You can't push them through the hole, and there is no opening to get a nut to the thread. Do you have a pic?
Are the QA1's stiff enough to prevent 1.5"-2" wheel travel?
joeg45
Katy, Tx
I cut the cup off off the back and welded a nut plate to the existing center hole and screwed them on or you can drill a hole on the top big enough to fit the nut and driver you use
The shocks have 18 setting to choose from as stiff as you need/want them or as soft me I keepine to the higher end as I like the stiffer ride so basically yes to that question it will still bottom on huge bumps but still good
TriSum
SoCal
EcoDiesel
Joe, did you get the compression and rebound adjustable or just compression?
David
Raadz
