3-way coolant valve
Rocketjam
Kenora Ontario
I've been getting intermittent engine code for the three-way coolant valve for over two years and not sure if I should change it out. Dealers want $700 plus but I found one for $140, still , not sure if its just a soft code. What happens if it does fail?
AFMoulton
Nuevo Mexico
1500? With 8sp? And Hemi or V6?
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Arsenal 18x9 +12mm
Cooper St MAXX LT295/70R18
66RFE/68RFE Thermo Bypass Valve Install
2016 Durango 5.7 AWD 3.07 Redline 5W-30 RP 10-48
1996 Nissan Altima 2.4 Amsoil SS 5W-30
R
Rocketjam
Kenora Ontario
1500 hemi with 8 speed. When the engine light is on it doesn’t go into eco mode but mileage doesn’t change
Tach_tech
5.7L HEMI
That’s the transmission thermal bypass valve.
The 3 way coolant valve is mounted on the passenger frame rail below the air filter housing.
As for OP, it’s a somewhat common failure, there was a PCM update for the errors but it rarely fixed it. More than likely you need a new 3-way valve.
Friednice
Raincity
5.7L hemispherical combustion chamber
those 3 way valves fail all the time, i also vote for a replacement, order one and a jug of coolant and do it on the drive way piece of cake.
AFMoulton
Nuevo Mexico
The thermal bypass video is pet of my signature.
But I agree with you, they are crap and require changed more than they should. Order a new one and replace. Make sure you get the correct coolant as it not green or orange
Tach_tech
5.7L HEMI
Oh ok, didn’t know that was part of your signature.
PoMansRam
East Aurora NY
You can also clamp off the hoses so you loose only a tiny bit of coolant during the swap out the 3-way valve.
drprymer
I just switched mine out Saturday. Paid $65 off of ebay takes about 20 mins to switch out. Clamped my hoses and lost minimal coolant. Mine was never throwing a code though, i just noticed it was leaking.
