I was having the same dilemma, but ultimately just decided with leveling for now and went with the Readylift kit with control arms. The 3.5" can leave you with some questionable angles for the suspension. Most people will probably be ok with it but will experience premature wear of some components. I also don't like preload spacers as they seem to stiffen the ride up quite a bit. I'll go with a proper 4" or 6" lift once more options become available.Looks really nice. I'm still trying to decide if I want to level mine or go with the 3.5" kit.
Sent from my SM-N950U using Tapatalk
Yeah, that's kinda what I was thinking. Just wait and go with a 4".I was having the same dilemma, but ultimately just decided with leveling for now and went with the Readylift kit with control arms. The 3.5" can leave you with some questionable angles for the suspension. Most people will probably be ok with it but will experience premature wear of some components. I also don't like preload spacers as they seem to stiffen the ride up quite a bit. I'll go with a proper 4" or 6" lift once more options become available.
Dont know much as to what the level is, I just went to my dealer and they put the 2 inch level on. For the tires I put KO2's size 285/65r20. They ride amazing and can't really notice much difference in regards from the stock duelers soundwise.Looks good, care to share more info as far as the level and the exact tires you’ve put on ?
Couldnt agree more and I like the extra space tooThe long bed looks much better!
CarPro Cquartz UK 2.0_50 MilliliterWhat coating did you go with?
Definately sits like 4-5 inches higher (2 inch from the level and like 2-3 inches from the tires) make it feel like I am drive in a heavy duty in regards to the height
