38's and 6 inch lift?
stepuptata
I have a 2008 with superlift 6 " lift..can I squeeze Kumho 38x15.50x20 Ventura MT and mt wels 20x12 4.5 B.S. on the truck?...What do I need to trim?
Thanks
4X HEMI
Lancaster County, PA
I'm thinking it might be pretty tight and you might have to do a lot of trimming. Granted the 2500's sit a little higher then the 1500's do but you might want to consider a body lift too, just to give you some extra room to play with.
ramhunter9
P-Star Jeep Wrangler
I wouldnt cut **** . Add a body lift . You start cutting into the fender pinch points (witch you will have to ) you are asking for rust .
I had 37" on for a small time and they fit with a 6" lift . No flex at all so I went back down to 35's . 38's no way definitely not with a 15.50
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Got Gears in that Heavy-Duty Rig or Diesel Torque? I mean to Turn such big Wheels!
Good Luck with the Lift Job! and welcome to the Site!
