4.6 Motor bogs once after starting
Arfowl
Running a 2003 with the 4.6 auto trans. After startup I can go about 3-4 hundred feet and the motor bogs down acts as if it's starving for fuel or air. If the accelerator is floored it will hesitate then pick back up, if left alone it will usually stop running. No codes have shown up. Have checked fuel rail 0ressure and it's in tolerance. Anyone got any ideas to toss out? Thanks!
Ajwalk2008
Springfield, il
Hope you mean 4.7.... Have you changed the air filter? I would clean the throttle body too as a start.
usaf2006
North Carolina
Dodge or Ford aside, it sounds like a lack of fuel pressure? Clogged filter maybe? Higher rpms keeps it going but without it it chokes out. Check that maybe? :)
huntergreen
Marine Corps Navy Badge
crank position sensor?
