Ramhemi12
Last Sunday I pulled the 5.7 intake off my 2012 to swap the 6.4 intake on. We had a family emergency and couldn't get back to it till Tuesday. Got to buttoning everything back up and My son touched alt end of battery wire straight to alternator body. It was a lot of sparks.
I reused the 5.7 throttle body and sensors along with the 6.4 intake and injectors.
Truck turns over but won't start. I have these 4 dtc codes
P0122-throttle position sensor 1 circuit low
P0222-throttle position sensor 2 curcuit low
P0642-Sensor Reference Voltage ‘A’ Circuit Low
P0882-TCM POWER INPUT LOW
Do you think this could be a shorted TIPM?
I found no blown fuses or bad relays. I tried a different throttle body. Even put the battery charger on to make sure the voltage was up.
