hunterdan
- Joined
- May 7, 2018
- Posts
- 1,189
- Reaction score
- 1,580
- Location
- SE PA
- Ram Year
- 2019 classic
- Engine
- 5.7 Hemi
So, I think the p219a code is kicked. Pretty sure it was addressed by the injector cleaning(s).
Still dealing with some hot restart issues and trying to iron them out. Have confirmed no injector leakage. Fuel pressure is holding after shut down, not bleeding down more than 1-3 psi. So, to me, rules out injectors and fuel pump/check valve. Fuel pressure through the PID and through a mechanical gauge line up. Only thing I'm thinking is there's a sensor that gets hot and sends some weird information back to the PCM at start up. As far as I can tell, ECT and intake temp look normal when I go to restart.
I am noticing that it doesn't start as crisp as it did on cold starts. It's better than a hot start, but it doesn't fire up as smoothly as it did. I'm wondering if maybe the cam sensor is sending some weird information back or possibly the crank sensor.
This motor hasn't been apart other than the intake manifold. Im also wondering if maybe the vvt phaser is sticking when it's hot and keeping the timing advanced. I've got a few days off coming up, so maybe I'll do an early oil change with a motor flush and see how that affects things. It certainly won't hurt to put new oil in. Oil filters have always opened up cleanly, with no signs of metal debris in them.
